On the notion of boundary conditions in comparison principles for viscosity solutions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We collect examples of boundary-value problems of Dirichlet and Dirichlet–Neumann type which we found instructive when designing and analysing numerical methods for fully nonlinear elliptic partial differential equations. In particular, our model problem is the Monge–Ampère equation, which is treated through its equivalent reformulation as a Hamilton–Jacobi–Bellman equation. Our examples illustrate how the different notions of boundary conditions appearing in the literature may admit different sets of viscosity sub-and supersolutions. We then discuss how these examples relate to the validity of comparison principles for these different notions of boundary conditions.
monge_ampere.pdf (474.56 Ko) Télécharger le fichier
hal-01493586 , version 1 (21-03-2017)
  • HAL Id : hal-01493586 , version 1
Max Jensen, Iain Smears. On the notion of boundary conditions in comparison principles for viscosity solutions. 2017. ⟨hal-01493586⟩
257 Consultations
205 Téléchargements
