Reports
Identifying the right replication level to detect and correct silent errors at scale
Abstract : This paper provides a model and an analytical study of replication as a technique to detect and correct silent errors. Although other detection techniques exist for HPC applications, based on algorithms (ABFT), invariant preservation or data analytics, replication remains the most transparent and least intrusive technique. We explore the right level (duplication, triplication or more) of replication needed to efficiently detect and correct silent errors. Replication is combined with checkpointing and comes with two flavors: \emph{process replication} and \emph{group replication}. Process replication applies to message-passing applications with communicating processes. Each process is replicated, and the platform is composed of process pairs, or triplets. Group replication applies to black-box applications, whose parallel execution is replicated several times. The platform is partitioned into two halves (or three thirds). In both scenarios, results are compared before each checkpoint, which is taken only when both results (duplication) or two out of three results (triplication) coincide. If not, one or more silent errors have been detected, and the application rolls back to the last checkpoint. We provide a detailed analytical study of both scenarios, with formulas to decide, for each scenario, the optimal parameters as a function of the error rate, checkpoint cost, and platform size. We also report a set of extensive simulation results that corroborates the analytical model.
Complete list of metadata
Cited literature [48 references]  Display  Hide  Download
https://hal.inria.fr/hal-01494678
Contributor : Equipe Roma Connect in order to contact the contributor
Submitted on : Thursday, March 23, 2017 - 6:20:14 PM
Last modification on : Friday, September 30, 2022 - 4:12:16 AM
Long-term archiving on: : Saturday, June 24, 2017 - 4:21:59 PM
File
RR-9047.pdf
Identifiers
  • HAL Id : hal-01494678, version 1
Collections
Citation
Anne Benoit, Aurélien Cavelan, Franck Cappello, Padma Raghavan, Yves Robert, et al.. Identifying the right replication level to detect and correct silent errors at scale. [Research Report] RR-9047, Inria Grenoble Rhône-Alpes, Université de Grenoble. 2017. ⟨hal-01494678⟩
Share
Metrics
Record views
152
Files downloads
137
