Identifying the right replication level to detect and correct silent errors at scale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Quel est le bon niveau de réplication pour détecter et corriger les erreurs silencieuses?
This paper provides a model and an analytical study of replication as a technique to detect and correct silent errors. Although other detection techniques exist for HPC applications, based on algorithms (ABFT), invariant preservation or data analytics, replication remains the most transparent and least intrusive technique. We explore the right level (duplication, triplication or more) of replication needed to efficiently detect and correct silent errors. Replication is combined with checkpointing and comes with two flavors: \emph{process replication} and \emph{group replication}. Process replication applies to message-passing applications with communicating processes. Each process is replicated, and the platform is composed of process pairs, or triplets. Group replication applies to black-box applications, whose parallel execution is replicated several times. The platform is partitioned into two halves (or three thirds). In both scenarios, results are compared before each checkpoint, which is taken only when both results (duplication) or two out of three results (triplication) coincide. If not, one or more silent errors have been detected, and the application rolls back to the last checkpoint. We provide a detailed analytical study of both scenarios, with formulas to decide, for each scenario, the optimal parameters as a function of the error rate, checkpoint cost, and platform size. We also report a set of extensive simulation results that corroborates the analytical model.
Ce rapport propose un modèle et une étude analytique de la réplication en tant que technique pour détecter et corriger les erreurs silencieuses. Bien que d'autres techniques existent pour les applications HPC, basées sur des algorithmes (ABFT), préservation d'invariant, ou analyse de données, la réplication reste la technique la plus transparente et la moins intrusive. Nous explorons le bon niveau (duplication, triplication ou plus) de réplication nécessaire pour détecter et corriger les erreurs silencieuses de manière efficace. La réplication est combinée avec des checkpoints et se présente sous deux formes : \emph{réplication de processus} et \emph{réplication de groupes}. La réplication de processus s'applique aux applications à passage de messages avec des processus communicants. Chaque processus est répliqué, et la plate-forme est composée de paires, ou triplets de processus. La réplication de groupe s'applique à des applications type boîte noire, dont l'exécution parallèle est répliquée plusieurs fois. La plate-forme est alors partitionnée en deux moitiés (ou trois tiers). Dans les deux scénarios, les résultats sont comparés avant chaque checkpoint, qui est effectué seulement lorsque les deux résultats (duplication) ou deux sur trois (triplication) coïncident. Sinon, une ou plusieurs erreurs silencieuses ont été détectées, et l'application redémarre depuis le dernier checkpoint. Nous proposons une étude analytique détaillée des deux scénarios ainsi que les paramètres optimaux fonction du taux d'erreur, du coût du checkpoint, et de la taille de la plate-forme. Nous donnons également les résultats d'un ensemble de simulations qui viennent corroborer le modèle analytique.
RR-9047.pdf (1.1 Mo) Télécharger le fichier
hal-01494678 , version 1 (23-03-2017)
  • HAL Id : hal-01494678 , version 1
Anne Benoit, Aurélien Cavelan, Franck Cappello, Padma Raghavan, Yves Robert, et al.. Identifying the right replication level to detect and correct silent errors at scale. [Research Report] RR-9047, Inria Grenoble Rhône-Alpes, Université de Grenoble. 2017. ⟨hal-01494678⟩
162 Consultations
166 Téléchargements
