Abstract : The random utility based multiregional input-output (RUBMRIO) model is used by several integrated land use and transportation models (ILUTMs) to forecast commodity flows in a region and for spatial allocation of production activities. It makes use of multiregional input-output models which are based on random utility theory. In this work, we use optimal control techniques to find optimal final demand and transportation costs of a RUBMRIO model, that would lead to a desired level of commodity flow and production costs. At first, the RUBMRIO model is formulated as a discrete time dynamical system. It is shown, using Lyapunov argument, that the fixed point of the dynamical system is input-to-state stable (ISS). Then, a discrete time optimal control problem is formulated with states as commodity flows and production costs, and the final demand and transportation costs as control inputs. An optimization problem is then solved to obtain control inputs that would lead to desired commodity flows and production costs. Further, the proposed methodology is applied to a numerical example. It is shown that the optimal control based method can achieve user specified commodity flows and production costs up to an acceptable accuracy level.
