Robust control of varying weak hyperspectral target detection with sparse non-negative representation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Signal Processing Année : 2017
In this study, a multiple-comparison approach is developed for detecting faint hyperspectral sources. The detection method relies on a sparse and non-negative representation on a highly coherent dictionary to track a spatially varying source. A robust control of the detection errors is ensured by learning the test statistic distributions on the data. The resulting control is based on the false discovery rate, to take into account the large number of pixels to be tested. This method is applied to data recently recorded by the three-dimensional spectrograph Multi-Unit Spectrograph Explorer (MUSE).
Mots clés
bacherTSP.pdf (991.88 Ko) Télécharger le fichier
hal-01496201 , version 1 (29-03-2017)
Raphael Bacher, Céline Meillier, Florent Chatelain, Olivier J.J. Michel. Robust control of varying weak hyperspectral target detection with sparse non-negative representation. IEEE Transactions on Signal Processing, 2017, 65 (13), pp.3538-3550. ⟨10.1109/TSP.2017.2688965⟩. ⟨hal-01496201⟩
352 Consultations
119 Téléchargements
