Relative scale estimation and 3D registration of multi-modal geometry using Growing Least Squares - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2015
The advent of low cost scanning devices and the improvement of multi-view stereo techniques have made the acquisition of 3D geometry ubiquitous. Data gathered from different devices, however, result in large variations in detail, scale, and coverage. Registration of such data is essential before visualizing, comparing and archiving them. However, state-of-the-art methods for geometry registration cannot be directly applied due to intrinsic differences between the models, e.g. sampling, scale, noise. In this paper we present a method for the automatic registration of multi-modal geometric data, i.e. acquired by devices with different properties (e.g. resolution, noise, data scaling). The method uses a descriptor based on Growing Least Squares, and is robust to noise, variation in sampling density, details, and enables scale-invariant matching. It allows not only the measurement of the similarity between the geometry surrounding two points, but also the estimation of their relative scale. As it is computed locally, it can be used to analyze large point clouds composed of millions of points. We implemented our approach in two registration procedures (assisted and automatic) and applied them successfully on a number of synthetic and real cases. We show that using our method, multi-modal models can be automatically registered, regardless of their differences in noise, detail, scale, and unknown relative coverage.
paper.pdf (6.32 Mo) Télécharger le fichier
Format : Figure, Image
hal-01498218 , version 1 (29-03-2017)
Nicolas Mellado, Matteo Dellepiane, Roberto Scopigno. Relative scale estimation and 3D registration of multi-modal geometry using Growing Least Squares. IEEE Transactions on Visualization and Computer Graphics, 2015, 22 (9), pp.14. ⟨10.1109/TVCG.2015.2505287⟩. ⟨hal-01498218⟩
249 Consultations
458 Téléchargements
