RAPter: Rebuilding Man-made Scenes with Regular Arrangements of Planes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2015
With the proliferation of acquisition devices, gathering massive volumes of 3D data is now easy. Processing such large masses of pointclouds, however, remains a challenge. This is particularly a problem for raw scans with missing data, noise, and varying sampling density. In this work, we present a simple, scalable, yet powerful data reconstruction algorithm. We focus on reconstructing man-made scenes as regular arrangements of planes (RAP), thereby selecting both local plane-based approximations along with their global inter-plane relations. We propose a novel selection formulation to directly balance between data fitting and the simplicity of the resulting arrangement of extracted planes. The main technical contribution is a formulation that allows less-dominant orientations to still retain their internal regularity, and not being overwhelmed and regularized by the dominant scene orientations. We evaluate our approach on a variety of complex 2D and 3D pointclouds, and demonstrate the advantages over existing alternative methods.
MonszpartEtAl_RAPter_SIGG15.pdf (42.02 Mo) Télécharger le fichier
MonszpartEtAl_RAPter_SIGG15_SupplementaryMaterial.pdf (51.7 Mo) Télécharger le fichier
hal-01498225 , version 1 (29-03-2017)
Aron Monszpart, Nicolas Mellado, Gabriel J Brostow, Niloy J Mitra. RAPter: Rebuilding Man-made Scenes with Regular Arrangements of Planes. ACM Transactions on Graphics, 2015, 34, pp.12. ⟨10.1145/2766995⟩. ⟨hal-01498225⟩
1035 Consultations
87 Téléchargements
