A Compiled Implementation of Strong Reduction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Benjamin Grégoire
Motivated by applications to proof assistants based on dependent types, we develop and prove correct a strong reducer and β-equivalence checker for the λ-calculus with products, sums, and guarded fixpoints. Our approach is based on compilation to the bytecode of an abstract machine performing weak reductions on non-closed terms, derived with minimal modifications from the ZAM machine used in the Objective Caml bytecode interpreter, and complemented by a recursive "read back" procedure. An implementation in the Coq proof assistant demonstrates important speed-ups compared with the original interpreter-based implementation of strong reduction in Coq.
strong-reduction.pdf (121.95 Ko) Télécharger le fichier
hal-01499941 , version 1 (01-04-2017)
Benjamin Grégoire, Xavier Leroy. A Compiled Implementation of Strong Reduction. ICFP '02: seventh ACM SIGPLAN international conference on Functional programming , ACM, Oct 2002, Pittsburgh, United States. pp.235-246, ⟨10.1145/581478.581501⟩. ⟨hal-01499941⟩
301 Consultations
471 Téléchargements
