The effectiveness of type-based unboxing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
We compare the efficiency of type-based unboxing strategies with that of simpler, untyped unboxing optimizations, building on our practical experience with the Gallium and Objective Caml compilers. We find the untyped optimizations to perform as well on the best case and significantly better in the worst case.
unboxing-tic97.pdf (167.13 Ko) Télécharger le fichier
hal-01499964 , version 1 (01-04-2017)
  • HAL Id : hal-01499964 , version 1
Xavier Leroy. The effectiveness of type-based unboxing. TIC 1997: Workshop Types in Compilation, Jun 1997, Amsterdam, Netherlands. ⟨hal-01499964⟩
Collections
INRIA INRIA2
387 Consultations
411 Téléchargements
