A User Study with GUIs Tailored for Smartphones - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
David Raneburger
  • Fonction : Auteur
  • PersonId : 1005530
Roman Popp
  • Fonction : Auteur
  • PersonId : 998961
Hermann Kaindl
  • Fonction : Auteur
  • PersonId : 998960
Jürgen Falb
  • Fonction : Auteur
  • PersonId : 1005532
Web-based graphical user interfaces (GUIs) are mostly not tailored for small devices with touchscreens, such as smartphones. There is little scientific evidence on the conditions where additional taps for navigation are better or scrolling. Therefore, we conducted a user study in which we evaluated different ways of tailoring a GUI for a smartphone. Each participant performed the same task with two different layouts of the same GUI. We collected quantitative data through measuring task completion time and error rates, as well as qualitative data through subjective questionnaires. The main result is that minimizing the number of taps is important on a smartphone. Users performed significantly better when they could scroll (vertically), instead of tapping on widget elements (tabs). This preference was also reflected in their subjective opinions.
978-3-642-40480-1_34_Chapter.pdf (266.51 Ko) Télécharger le fichier
hal-01501767 , version 1 (04-04-2017)
Paternité
David Raneburger, David Alonso-Ríos, Roman Popp, Hermann Kaindl, Jürgen Falb. A User Study with GUIs Tailored for Smartphones. 14th International Conference on Human-Computer Interaction (INTERACT), Sep 2013, Cape Town, South Africa. pp.505-512, ⟨10.1007/978-3-642-40480-1_34⟩. ⟨hal-01501767⟩
113 Consultations
166 Téléchargements
