The Evolution of Number Entry: A Case Study of the Telephone - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Parisa Eslambolchilar
  • Fonction : Auteur
  • PersonId : 1005536
Julie Webster
  • Fonction : Auteur
  • PersonId : 1005537
Gerrit Niezen
  • Fonction : Auteur
  • PersonId : 1005538
This paper details a user study to investigate serial digit entry on analogue and digital input platforms and the errors associated with them. We look specifically at the case of entering eleven-digit telephone numbers without a decimal point. The telephone is used as a platform for comparison, due to its clear evolution from a rotary dial to a pushbutton keypad and more recently, touch-based input. Thirty participants took part in a user study, which concluded that the touch interface was four times less accurate than the pushbutton and rotary dial interfaces. The latter two interfaces performed with similar accuracy; however, users were more than three times faster on the pushbutton keypad and recognized almost twice as many errors on the rotary dial. We have extended previous error taxonomies to include some errors relevant to sequences of numbers and built upon task-based guidelines found in the literature to suggest context-based design considerations.
978-3-642-40480-1_37_Chapter.pdf (240.24 Ko) Télécharger le fichier
hal-01501770 , version 1 (04-04-2017)
Paternité
Parisa Eslambolchilar, Julie Webster, Gerrit Niezen. The Evolution of Number Entry: A Case Study of the Telephone. 14th International Conference on Human-Computer Interaction (INTERACT), Sep 2013, Cape Town, South Africa. pp.538-545, ⟨10.1007/978-3-642-40480-1_37⟩. ⟨hal-01501770⟩
66 Consultations
79 Téléchargements
