Comparison between SPT and PT for defect characterization of CFRP plates glued on concrete or wood structures using optical active infrared thermography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The objectives of the study summarized hereafter are to compare square pulse and pulsed thermography for defect detection and characterization of CFRP plates used as structural reinforcement in Civil Engineering applications. Image processing and an inverse method coupled with thermal quadrupoles model are also studied.
Dumoulin_Criniere_Ibarra_et_al_QIRT_2012_IFSTTAR_MIVIM_Final.doc.pdf (782.99 Ko) Télécharger le fichier
QIRT-2012-375abs.pdf (631.64 Ko) Télécharger le fichier
hal-01502629 , version 1 (05-04-2017)
  • HAL Id : hal-01502629 , version 1
Antoine Crinière, Jean Dumoulin, Clemente Ibarra Castanedo, Louis-Daniel Théroux, Xavier Maldague. Comparison between SPT and PT for defect characterization of CFRP plates glued on concrete or wood structures using optical active infrared thermography. QIRT 2012 - 11th International Conference on Quantitative InfraRed Thermography, Jun 2012, Naples, Italy. ⟨hal-01502629⟩
225 Consultations
113 Téléchargements
