Survival of the Shortest: A Retrospective Analysis of Influencing Factors on Password Composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Emanuel Von Zezschwitz
  • Fonction : Auteur
  • PersonId : 1005900
Alexander De Luca
  • Fonction : Auteur
  • PersonId : 1005901
Heinrich Hussmann
  • Fonction : Auteur
  • PersonId : 1005902
In this paper, we investigate the evolutionary change of user-selected passwords. We conducted one-on-one interviews and analyzed the complexity and the diversity of users’ passwords using different analysis tools. By comparing their first-ever created passwords to several of their currently used passwords (e.g. most secure, policy-based), we were able to trace password reuse, password changes and influencing factors on the evolutionary process. Our approach allowed for analyzing security aspects without actually knowing the clear-text passwords. The results reveal that currently used passwords are significantly longer than the participants’ first passwords and that most participants are aware of how to compose strong passwords. However, most users are still using significantly weaker passwords for most services. These weak passwords, often with roots in the very first passwords the users have chosen, apparently survive very well, despite password policies and password meters.
978-3-642-40477-1_28_Chapter.pdf (978.48 Ko) Télécharger le fichier
hal-01504901 , version 1 (10-04-2017)
Paternité
Emanuel Von Zezschwitz, Alexander De Luca, Heinrich Hussmann. Survival of the Shortest: A Retrospective Analysis of Influencing Factors on Password Composition. 14th International Conference on Human-Computer Interaction (INTERACT), Sep 2013, Cape Town, South Africa. pp.460-467, ⟨10.1007/978-3-642-40477-1_28⟩. ⟨hal-01504901⟩
152 Consultations
177 Téléchargements
