Ageing, Technology Anxiety and Intuitive Use of Complex Interfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Raghavendra Reddy Gudur
  • Fonction : Auteur
  • PersonId : 1005923
Alethea Blackler
  • Fonction : Auteur
  • PersonId : 1005924
Vesna Popovic
  • Fonction : Auteur
  • PersonId : 1005925
Doug Mahar
  • Fonction : Auteur
  • PersonId : 1005926
This paper presents the outcome of a study that investigated the relationships between technology prior experience, self-efficacy, technology anxiety, complexity of interface (nested versus flat) and intuitive use in older people. The findings show that, as expected, older people took less time to complete the task on the interface that used a flat structure when compared to the interface that used a complex nested structure. All age groups also used the flat interface more intuitively. However, contrary to what was hypothesised, older age groups did better under anxious conditions. Interestingly, older participants did not make significantly more errors compared with younger age groups on either interface structures.
978-3-642-40477-1_36_Chapter.pdf (780.94 Ko) Télécharger le fichier
hal-01504910 , version 1 (10-04-2017)
Paternité
Raghavendra Reddy Gudur, Alethea Blackler, Vesna Popovic, Doug Mahar. Ageing, Technology Anxiety and Intuitive Use of Complex Interfaces. 14th International Conference on Human-Computer Interaction (INTERACT), Sep 2013, Cape Town, South Africa. pp.564-581, ⟨10.1007/978-3-642-40477-1_36⟩. ⟨hal-01504910⟩
72 Consultations
131 Téléchargements
