BSDEs with no driving martingale, Markov processes and associated Pseudo Partial Differential Equations. Part II: Decoupled mild solutions and Examples. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Let $(\mathbb{P}^{s,x})_{(s,x)\in[0,T]\times E}$ be a family of probability measures, where $E$ is a Polish space,defined on the canonical probability space ${\mathbb D}([0,T],E)$ of $E$-valued cadlag functions. We suppose that a martingale problem with respect to a time-inhomogeneous generator $a$ is well-posed. We consider also an associated semilinear {\it Pseudo-PDE} with generator $a$ for which we introduce a notion of so called {\it decoupled mild} solution and study the equivalence with the notion of martingale solution introduced in a companion paper. We also investigate well-posedness for decoupled mild solutions and their relations with a special class of BSDEs without driving martingale. The notion of decoupled mild solution is a good candidate to replace the notion of viscosity solution which is not always suitable when the map $a$ is not a PDE operator.
PseudoPDE_BR_2020.pdf (399.88 Ko) Télécharger le fichier
hal-01505974 , version 1 (12-04-2017)
hal-01505974 , version 2 (05-04-2020)
hal-01505974 , version 3 (26-11-2020)
hal-01505974 , version 4 (10-05-2021)
Adrien Barrasso, Francesco Russo. BSDEs with no driving martingale, Markov processes and associated Pseudo Partial Differential Equations. Part II: Decoupled mild solutions and Examples.. 2020. ⟨hal-01505974v3⟩
294 Consultations
139 Téléchargements
