Cumulus4j: A Provably Secure Database Abstraction Layer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Matthias Huber
  • Fonction : Auteur
  • PersonId : 1006143
Matthias Gabel
  • Fonction : Auteur
  • PersonId : 1006144
Marco Schulze
  • Fonction : Auteur
  • PersonId : 1006145
Alexander Bieber
  • Fonction : Auteur
  • PersonId : 1006146
Cloud Computing has huge impact on IT systems. It offers advantages like flexibility and reduced costs. Privacy and security issues, however, remain a major drawback. While data can be secured against external threats using standard techniques, service providers themselves have to be trusted to ensure privacy.In this paper, we present a novel technique for secure database outsourcing. We provide the security notion Ind-ICP that focuses on hiding relations between values. We prove the security of our approach and present benchmarks showing the practicability of this solution. Furthermore, we developed a plug-in for a persistence layer. Our plug-in de- and encrypts sensitive data transparently to the client application. By using encrypted indices, queries can still be executed efficiently.
978-3-642-40588-4_13_Chapter.pdf (319.55 Ko) Télécharger le fichier
hal-01506571 , version 1 (12-04-2017)
Paternité
  • HAL Id : hal-01506571 , version 1
Matthias Huber, Matthias Gabel, Marco Schulze, Alexander Bieber. Cumulus4j: A Provably Secure Database Abstraction Layer. 1st Cross-Domain Conference and Workshop on Availability, Reliability, and Security in Information Systems (CD-ARES), Sep 2013, Regensburg, Germany. pp.180-193. ⟨hal-01506571⟩
107 Consultations
86 Téléchargements
