On the Security of LBlock against the Cube Attack and Side Channel Cube Attack - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2013
In this research, a recently proposed lightweight block cipher LBlock, not tested against the cube attack has been analyzed. 7, 8 and 9 round LBlock have been successfully attacked with complexities of O(210.76), O(211.11) and O(247.00) respectively. For the case of side channel cube attack, full version of LBlock has been attacked using a single bit leakage model with the complexity of O(255.00) cipher evaluations. For this purpose, a generic practical platform has been developed to test various stream and block ciphers against the latest cube attack.
978-3-642-40588-4_8_Chapter.pdf (642.02 Ko) Télécharger le fichier
Dates and versions
hal-01506698 , version 1 (12-04-2017)
Attribution
Identifiers
  • HAL Id : hal-01506698 , version 1
Cite
Saad Islam, Mehreen Afzal, Adnan Rashdi. On the Security of LBlock against the Cube Attack and Side Channel Cube Attack. 1st Cross-Domain Conference and Workshop on Availability, Reliability, and Security in Information Systems (CD-ARES), Sep 2013, Regensburg, Germany. pp.105-121. ⟨hal-01506698⟩
61 View
322 Download
Share
