ChEA2: Gene-Set Libraries from ChIP-X Experiments to Decode the Transcription Regulome - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
ChIP-seq experiments provide a plethora of data regarding transcription regulation in mammalian cells. Integrating ChIP-seq studies into a computable resource is potentially useful for further knowledge extraction from such data. We continually collect and expand a database where we convert results from ChIP-seq experiments into gene-set libraries. The manual portion of this database currently contains 200 transcription factors from 221 publications for a total of 458,471 transcription-factor/target interactions. In addition, we automatically compiled data from the ENCODE project which includes 920 experiments applied to 44 cell-lines profiling 160 transcription factors for a total of ~1.4 million transcription-factor/target-gene interactions. Moreover, we processed data from the NIH Epigenomics Roadmap project for 27 different types of histone marks in 64 different human cell-lines. All together the data was processed into three simple gene-set libraries where the set label is either a mammalian transcription factor or a histone modification mark in a particular cell line, organism and experiment. Such gene-set libraries are useful for elucidating the experimentally determined transcriptional networks regulating lists of genes of interest using gene-set enrichment analyses. Furthermore, from these three gene-set libraries, we constructed regulatory networks of transcription factors and histone modifications to identify groups of regulators that work together. For example, we found that the Polycomb Repressive Complex 2 (PRC2) is involved with three distinct clusters each interacting with different sets of transcription factors. Notably, the combined dataset is made into web-based application software where users can perform enrichment analyses or download the data in various formats. The open source ChEA2 web-based software and datasets are available freely online at http://amp.pharm.mssm.edu/ChEA2.
978-3-642-40511-2_30_Chapter.pdf (1.47 Mo) Télécharger le fichier
hal-01506771 , version 1 (12-04-2017)
Paternité
  • HAL Id : hal-01506771 , version 1
Yan Kou, Edward Y. Chen, Neil R. Clark, Qiaonan Duan, Christopher M. Tan, et al.. ChEA2: Gene-Set Libraries from ChIP-X Experiments to Decode the Transcription Regulome. 1st Cross-Domain Conference and Workshop on Availability, Reliability, and Security in Information Systems (CD-ARES), Sep 2013, Regensburg, Germany. pp.416-430. ⟨hal-01506771⟩
274 Consultations
304 Téléchargements
