Infrared Thermography applied to transport infrastructures monitoring: outcomes and perspectives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Long term monitoring of transport infrastructures by infrared thermography has been studied and tested on different structures. A first standalone infrared system architecture developed is presented and discussed. Results obtained with such system on different Civil Engineering structures are presented. Some data processing approaches and inverse thermal model for data analysis are introduced and discussed. Lessons learned from experiments carried out in outdoor with such system are listed and analyzed. Then, a new generation of infrared system architecture is proposed. Finally, conclusions and perspectives are addressed.
spie_DCS_2017_JD_AC_Final.pdf (14.3 Mo) Télécharger le fichier
hal-01509555 , version 1 (18-04-2017)
  • HAL Id : hal-01509555 , version 1
Jean Dumoulin, Antoine Crinière. Infrared Thermography applied to transport infrastructures monitoring: outcomes and perspectives. SPIE - Thermosense: Thermal Infrared Applications XXXIX, Apr 2017, Anaheim California, United States. ⟨hal-01509555⟩
320 Consultations
204 Téléchargements
