Discrete motor imageries can be used to allow a faster detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Motor imagery (MI) modifies the neural activity within the primary sensorimotor areas of the cortex and can be measured through the analysis of elec-troencephalographic (EEG) recordings. It is particularly interesting for Brain-Computer Interface (BCI) applications. In most MI-based BCI experimental paradigms, subjects realize continuous motor imagery (CMI), i.e. a repetitive and prolonged intention of movement, for a few seconds. The system detects the movement based on the event-related desynchronization and the event-related synchronization features in electroencephalographic signal. Currently, improving efficiency such as detecting faster a motor imagery is an important issue in BCI to avoid fatigue and boredom. The purpose of this study is to show the difference, in term of classification, between a discrete motor imagery, i.e. a single short MI, and a CMI. The results of experiments involving 16 healthy subjects show that a BCI based on DMI is as effective as a BCI based on CMI and could be used to allow a faster detection.
BCIconfGraz2017_DiscreteMotorImageryClassification.pdf (1.59 Mo) Télécharger le fichier
hal-01512407 , version 1 (22-04-2017)
  • HAL Id : hal-01512407 , version 1
Sébastien Rimbert, Oleksii Avilov, Laurent Bougrain. Discrete motor imageries can be used to allow a faster detection. 7th Graz Brain-Computer Interface Conference 2017, Sep 2017, Graz, Austria. ⟨hal-01512407⟩
320 Consultations
156 Téléchargements
