Speeding Up Galois Field Arithmetic on Intel MIC Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kai Feng
  • Fonction : Auteur
Wentao Ma
  • Fonction : Auteur
Wei Huang
  • Fonction : Auteur
Yili Gong
  • Fonction : Auteur
  • PersonId : 1006898
Galois Field arithmetic is the basis of LRC, RS and many other erasure coding approaches. Traditional implementations of Galois Field arithmetic use multiplication tables or discrete logarithms, which limit the speed of its computation. The Intel Many Integrated Core (MIC) Architecture provides 60 cores on chip and very wide 512-bit SIMD instructions, attractive for data intensive applications. This paper demonstrates how to leverage SIMD instructions and shared memory multiprocessing on MIC to perform Galois Field arithmetic. The experiments show that the performance of the computation is significantly enhanced.
978-3-642-40820-5_13_Chapter.pdf (1.31 Mo) Télécharger le fichier
hal-01513765 , version 1 (25-04-2017)
Paternité
Kai Feng, Wentao Ma, Wei Huang, Qing Zhang, Yili Gong. Speeding Up Galois Field Arithmetic on Intel MIC Architecture. 10th International Conference on Network and Parallel Computing (NPC), Sep 2013, Guiyang, China. pp.143-154, ⟨10.1007/978-3-642-40820-5_13⟩. ⟨hal-01513765⟩
123 Consultations
388 Téléchargements
