A Network-Aware Virtual Machine Allocation in Cloud Datacenter - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2013
In a cloud computing environment, virtual machine allocation is an important task for providing infrastructure services. Generally, the datacenters, on which a cloud computing platform runs, are distributed over a wide area network. Therefore, communication cost should be taken into consideration when allocating VMs across servers of multiple datacenters. A network-aware VM allocation algorithm for cloud is developed. It tries to minimize the communication cost and latency between servers, with the number of VMs, VM configurations and communication bandwidths are satisfied to users. Specifically, a two-dimensional knapsack algorithm is applied to solve this problem. The algorithm is evaluated and compared with other ones through experiments, which shows satisfying results.
978-3-642-40820-5_7_Chapter.pdf (637.64 Ko) Télécharger le fichier
Dates and versions
hal-01513773 , version 1 (25-04-2017)
Attribution
Identifiers
Cite
Yan Yao, Jian Cao, Minglu Li. A Network-Aware Virtual Machine Allocation in Cloud Datacenter. 10th International Conference on Network and Parallel Computing (NPC), Sep 2013, Guiyang, China. pp.71-82, ⟨10.1007/978-3-642-40820-5_7⟩. ⟨hal-01513773⟩
137 View
278 Download
Share
