Delta Modeling and Model Checking of Product Families - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Software product line engineering focuses on proactive reuse to reduce the cost of developing families of related systems. A recently proposed method to develop software product lines is delta modeling where a set of deltas specify modifications that should be applied to a core product to achieve other products. The main advantage of this technique is its modularity and flexibility. In this paper, we propose an approach to model check delta-oriented product lines. To this end, we transform a delta model to a corresponding annotated model where an application condition is associated to each statement. An application condition specifies the set of products that a statement is included in them. We present the semantics of the resulting model in form of a featured transition system where each transition is annotated with an application condition. Featured transition systems are supported by a variability-aware model checking technique that can be used to verify the annotated model.
978-3-642-40213-5_4_Chapter.pdf (322.97 Ko) Télécharger le fichier
hal-01514656 , version 1 (26-04-2017)
Paternité
Hamideh Sabouri, Ramtin Khosravi. Delta Modeling and Model Checking of Product Families. 5th International Conference on Fundamentals of Software Engineering (FSEN), Apr 2013, Tehran, Iran. pp.51-65, ⟨10.1007/978-3-642-40213-5_4⟩. ⟨hal-01514656⟩
46 Consultations
60 Téléchargements
