Comparing two clusterings using matchings between clusters of clusters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Clustering is a fundamental problem in data science, yet, the variety of clustering methods and their sensitivity to parameters make clustering hard. To analyze the stability of a given clustering algorithm while varying its parameters, and to compare clusters yielded by different algorithms, several comparison schemes based on matchings, information theory and various indices (Rand, Jaccard) have been developed. We go beyond these by providing a novel class of methods computing meta-clusters within each clustering– a meta-cluster is a group of clusters, together with a matching between these. Let the intersection graph of two clusterings be the edge-weighted bipartite graph in which the nodes represent the clusters, the edges represent the non empty intersection between two clusters, and the weight of an edge is the number of common items. We introduce the so-called D-family-matching problem on intersection graphs, with D the upper-bound on the diameter of the graph induced by the clusters of any meta-cluster. First we prove NP-completeness results and unbounded approximation ratio of simple strategies. Second, we design exact polynomial time dynamic programming algorithms for some classes of graphs (in particular trees). Then, we prove spanning-tree based efficient algorithms for general graphs. Our experiments illustrate the role of D as a scale parameter providing information on the relationship between clusters within a clustering and in-between two clusterings. They also show the advantages of our built-in mapping over classical cluster comparison measures such as the variation of information (VI).
RR-9063-family-matching.pdf (3.24 Mo) Télécharger le fichier
hal-01514872 , version 1 (26-04-2017)
hal-01514872 , version 2 (29-09-2017)
hal-01514872 , version 3 (01-02-2019)
hal-01514872 , version 4 (16-07-2019)
  • HAL Id : hal-01514872 , version 3
Frédéric Cazals, Dorian Mazauric, Romain Tetley, Rémi Watrigant. Comparing two clusterings using matchings between clusters of clusters. [Research Report] RR-9063, INRIA Sophia Antipolis - Méditerranée; Universite Cote d'Azur. 2017, pp.1-45. ⟨hal-01514872v3⟩
541 Consultations
4393 Téléchargements
