HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
An interface to implement NUMA policies in the Xen hypervisor
Abstract : While virtualization only introduces a small overhead on machines with few cores, this is not the case on larger ones. Most of the overhead on the latter machines is caused by the Non-Uniform Memory Access (NUMA) architecture they are using. In order to reduce this overhead, this paper shows how NUMA placement heuristics can be implemented inside Xen. With an evaluation of 29 applications on a 48-core machine, we show that the NUMA placement heuristics can multiply the performance of 9 applications by more than 2.
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/hal-01515359
Contributor : Pierre Sens Connect in order to contact the contributor
Submitted on : Thursday, April 27, 2017 - 1:13:50 PM
Last modification on : Tuesday, March 22, 2022 - 11:10:10 AM
File
voron17eurosys-xen-numa.pdf
Identifiers
  • HAL Id : hal-01515359, version 1
Citation
Gauthier Voron, Gaël Thomas, Vivien Quema, Pierre Sens. An interface to implement NUMA policies in the Xen hypervisor. Twelfth European Conference on Computer Systems, EuroSys 2017, Apr 2017, Belgrade, Serbia. pp.15. ⟨hal-01515359⟩
Share
Metrics
Record views
526
Files downloads
477
