An interface to implement NUMA policies in the Xen hypervisor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
While virtualization only introduces a small overhead on machines with few cores, this is not the case on larger ones. Most of the overhead on the latter machines is caused by the Non-Uniform Memory Access (NUMA) architecture they are using. In order to reduce this overhead, this paper shows how NUMA placement heuristics can be implemented inside Xen. With an evaluation of 29 applications on a 48-core machine, we show that the NUMA placement heuristics can multiply the performance of 9 applications by more than 2.
voron17eurosys-xen-numa.pdf (382.03 Ko) Télécharger le fichier
hal-01515359 , version 1 (27-04-2017)
Paternité
  • HAL Id : hal-01515359 , version 1
Gauthier Voron, Gaël Thomas, Vivien Quema, Pierre Sens. An interface to implement NUMA policies in the Xen hypervisor. Twelfth European Conference on Computer Systems, EuroSys 2017, Apr 2017, Belgrade, Serbia. pp.15. ⟨hal-01515359⟩
573 Consultations
566 Téléchargements
