Monitoring Business Processes in the Networked Enterprise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cinzia Cappiello
  • Fonction : Auteur
  • PersonId : 1007089
Angelo Corallo
  • Fonction : Auteur
  • PersonId : 990011
Barbara Pernici
  • Fonction : Auteur
  • PersonId : 957266
Pierluigi Plebani
  • Fonction : Auteur
  • PersonId : 1007091
Davide Storelli
  • Fonction : Auteur
  • PersonId : 1007092
The Object Management Group (OMG) is promoting the Model Driven Architecture (MDA) approach to support interaction among enterprises based on business process models. Based on this approach, we discuss in this paper how to specify performance indicators among the levels with different degree of abstraction suggested in MDA. These indicators will drive the monitoring activities to check the execution of business processes involving networked enterprises. Connecting the different levels we also decrease the cost of implementing metrics as the measurement of the entities at one level can be based on the lower level.
978-3-642-34044-4_2_Chapter.pdf (327.15 Ko) Télécharger le fichier
hal-01515540 , version 1 (27-04-2017)
Paternité
Francesco Arigliano, Devis Bianchini, Cinzia Cappiello, Angelo Corallo, Paolo Ceravolo, et al.. Monitoring Business Processes in the Networked Enterprise. 1st International Symposium on Data-Driven Process Discovery and Analysis (SIMPDA), Jun 2011, Campione d’Italia, Italy. pp.21-38, ⟨10.1007/978-3-642-34044-4_2⟩. ⟨hal-01515540⟩
53 Consultations
80 Téléchargements
