Striving for Object-Aware Process Support: How Existing Approaches Fit Together - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Many limitations of contemporary process management systems (PrMS) can be traced back to the missing integration of processes and data. A unified understanding of the inherent relationships existing between processes and data, however, is still missing. In the PHILharmonicFlows project we figured out that process support often requires object-awareness. This means, data must be manageable in terms of object types comprising object attributes and relations to other object types. In this paper, we systematically introduce the fundamental characteristics of object-aware processes. Further, we elaborate existing approaches recognizing the need for a tighter integration of processes and data along these characteristics. This way, we show the high relevance of the identified characteristics and confirm that their support is needed in many application domains.
978-3-642-34044-4_10_Chapter.pdf (7.15 Mo) Télécharger le fichier
hal-01515547 , version 1 (27-04-2017)
Paternité
Vera Künzle, Manfred Reichert. Striving for Object-Aware Process Support: How Existing Approaches Fit Together. 1st International Symposium on Data-Driven Process Discovery and Analysis (SIMPDA), Jun 2011, Campione d’Italia, Italy. pp.169-188, ⟨10.1007/978-3-642-34044-4_10⟩. ⟨hal-01515547⟩
117 Consultations
51 Téléchargements
