Product Semantics in Design Research Practice - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jonas Sjöström
  • Fonction : Auteur
  • PersonId : 1007168
Brian Donnellan
  • Fonction : Auteur
  • PersonId : 1007169
Markus Helfert
  • Fonction : Auteur
  • PersonId : 987151
The concept of product semantics and its focus on meaning is used to interpret design research as design. It is argued that we may conceive of design research as design in two realms: The practical and the academic. In doing design research, there is a reciprocal shaping of artifacts: Better artifacts (contributions to practice) through appropriation of knowledge and methods from the academic realm, and better knowledge artifacts (contributions to academia) by drawing relevance and experiences of appropriation from the practical realm. We adopt a product semantics view to discuss research as design. Product semantics highlights the meaning of artifacts with respect to their (i) stakeholders, (ii) artifacts-in-use, (iii), artifacts-in-language, (iv) artifact lifecycle, and (v) ecology. Based on this interpretation, we propose activities that should characterize the practice of doing design research. Finally we provide an example of Design Research Practice in action.
978-3-642-35142-6_3_Chapter.pdf (273.99 Ko) Télécharger le fichier
hal-01515847 , version 1 (28-04-2017)
Paternité
Jonas Sjöström, Brian Donnellan, Markus Helfert. Product Semantics in Design Research Practice. Working COnference on Shaping the Future of ICT Research, Dec 2012, Tampa, FL, United States. pp.35-48, ⟨10.1007/978-3-642-35142-6_3⟩. ⟨hal-01515847⟩
425 Consultations
264 Téléchargements
