Control Electronics Integration toward Endoscopic Capsule Robot Performing Legged Locomotion and Illumination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Miniaturization of sensors and actuators up to the point of active features in endoscopic capsules, such as locomotion or surgery, is a challenge. VECTOR endoscopic capsule has been designed to be the first endoscopic capsule with active locomotion. It is equipped with mini-legs driven by Brushless DC (BLDC) micro motors. In addition it can be also equipped with some other sensors and actuators, like a liquid lens, that permits to enable advanced functions. Those modules are managed by an Application Specific Integrated Circuit (ASIC) specifically designed for the VECTOR capsule. The ASIC is a complete System-On-Chip (SoC) and integrates all the electronics needed to enable the legged locomotion and the sensing and actuating functions of the capsule in an unique chip. The SoC also permits other functions for endoscopic capsules such as drug delivery and biopsy. The size of the SoC is 5.1 mm x 5.2 mm in a 0.35 μm high voltage CMOS technology.
978-3-642-28566-0_13_Chapter.pdf (1.16 Mo) Télécharger le fichier
hal-01515997 , version 1 (28-04-2017)
Paternité
Oscar Alonso, Angel Diéguez. Control Electronics Integration toward Endoscopic Capsule Robot Performing Legged Locomotion and Illumination. 18th International Conference on Very Large Scale Integration (VLSISOC), Sep 2010, Madrid, Spain. pp.312-338, ⟨10.1007/978-3-642-28566-0_13⟩. ⟨hal-01515997⟩
138 Consultations
533 Téléchargements
