An Industrial Viewpoint on Uncertainty Quantification in Simulation: Stakes, Methods, Tools, Examples - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alberto Pasanisi
  • Fonction : Auteur
  • PersonId : 957102
Anne Dutfoy
  • Fonction : Auteur
  • PersonId : 963282
Simulation is nowadays a major tool in R&D and engineering studies. In industrial practice, in both design and operating stages, the behavior of a complex system is described and forecast by a computer model, which is, most of time, deterministic. Yet, engineers coping with quantitative predictions using deterministic models deal actually with several sources of uncertainties affecting the inputs (and occasionally the model itself) which are transferred to the outputs. Therefore, uncertainty quantification in simulation has garnered increased importance in recent years. In this paper we present an industrial viewpoint of this practice. After a reminder of the main stakes related to uncertainty quantification and probabilistic computing, we will focus on the specific methodology and software tools which have been developed for treating this problem at EDF R&D. We conclude with examples illustrating applied studies recently performed by EDF R&D engineers arising from different physical domains.
978-3-642-32677-6_3_Chapter.pdf (502.34 Ko) Télécharger le fichier
hal-01518664 , version 1 (05-05-2017)
Paternité
Alberto Pasanisi, Anne Dutfoy. An Industrial Viewpoint on Uncertainty Quantification in Simulation: Stakes, Methods, Tools, Examples. 10th Working Conference on Uncertainty Quantification in Scientific Computing (WoCoUQ), Aug 2011, Boulder, CO, United States. pp.27-45, ⟨10.1007/978-3-642-32677-6_3⟩. ⟨hal-01518664⟩
56 Consultations
300 Téléchargements
