Uncertainty and Sensitivity Analysis: From Regulatory Requirements to Conceptual Structure and Computational Implementation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jon C. Helton
  • Fonction : Auteur
  • PersonId : 1007588
An approach to the conversion of regulatory requirements into a conceptual and computational structure that permits meaningful uncertainty and sensitivity analyses is descibed. This approach is predicated on the description of the desired analysis in terms of three basic entities: (i) a probability space characterizing aleatory uncertainty, (ii) a probability space characterizing epistemic uncertainty, and (iii) a model that predicts system behavior. The presented approach is illustrated with results from the 2008 performance assessment for the proposed repository for high-level radioactive waste at Yucca Mountain, Nevada.
978-3-642-32677-6_5_Chapter.pdf (439.72 Ko) Télécharger le fichier
hal-01518668 , version 1 (05-05-2017)
Paternité
Jon C. Helton, Cédric J. Sallaberry. Uncertainty and Sensitivity Analysis: From Regulatory Requirements to Conceptual Structure and Computational Implementation. 10th Working Conference on Uncertainty Quantification in Scientific Computing (WoCoUQ), Aug 2011, Boulder, CO, United States. pp.60-77, ⟨10.1007/978-3-642-32677-6_5⟩. ⟨hal-01518668⟩
182 Consultations
63 Téléchargements
