Emerging Hackerspaces – Peer-Production Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jarkko Moilanen
  • Fonction : Auteur
  • PersonId : 1007686
This paper describes a peer-production movement, the hackerspace movement, its members and values. The emergence of hackerspaces, fablabs and makerspaces is changing how hacker communities and other like-minded communities function. Thus, an understanding of the nature of hackerspaces helps in detailing the features of contemporary peer-production. Building on previous work on ’fabbing’, two different sets of results are presented: (1) empirical observations from a longitudinal study of hackerspace participants; and (2) a theoretical description of hacker generations as a larger context in which peer-production can be located. With regard to (1), research data has been collected through prolonged observation of hackerspace communities and two surveys.
978-3-642-33442-9_7_Chapter.pdf (564.88 Ko) Télécharger le fichier
hal-01519057 , version 1 (05-05-2017)
Paternité
Jarkko Moilanen. Emerging Hackerspaces – Peer-Production Generation. 8th International Conference on Open Source Systems (OSS), Sep 2012, Hammamet, Tunisia. pp.94-111, ⟨10.1007/978-3-642-33442-9_7⟩. ⟨hal-01519057⟩
77 Consultations
332 Téléchargements
