A Classical Sequent Calculus with Dependent Types (Extended Version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Dependent types are a key feature of the proof assistants based on the Curry-Howard isomorphism. It is well-known that this correspondence can be extended to classical logic by enriching the language of proofs with control operators. However, they are known to misbehave in the presence of dependent types, unless dependencies are restricted to values. Moreover, while sequent calculi are naturally tailored to smoothly support continuation-passing style interpretations, there is no such presentation of a language with dependent types. The main achievement of this paper is to give a sequent calculus presentation of a call-by-value language with a control operator and dependent types, and to justify its soundness through a continuation-passing style translation. We start from the call-by-value version of the λµμ̃-calculus. We design a minimal language with a value restriction and a type system that includes a list of explicit dependencies to maintains type safety. We then show how to relax the value restriction and introduce delimited continuations to directly prove the consistency by means of a continuation-passing-style translation. Finally, we relate our calculus to a similar system by Lepigre, and present a methodology to transfer properties from this system to our own.
dL-HAL.pdf (955.54 Ko) Télécharger le fichier
hal-01519929 , version 1 (09-05-2017)
hal-01519929 , version 2 (01-12-2017)
hal-01519929 , version 3 (15-12-2018)
  • HAL Id : hal-01519929 , version 2
Étienne Miquey. A Classical Sequent Calculus with Dependent Types (Extended Version). 2017. ⟨hal-01519929v2⟩
Collections
UNIV-PARIS7
700 Consultations
989 Téléchargements
