Programmable 2D Arrangements for Element Texture Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2017
This paper introduces a programmable method for designing stationary 2D arrangements for element textures, namely textures made of small geometric elements. These textures are ubiquitous in numerous applications of computer-aided illustration. Previous methods, whether they be example-based or layout-based, lack control and can produce a limited range of possible arrangements. Our approach targets technical artists who will design an arrangement by writing a script. These scripts are using three types of operators: partitioning operators for defining the broad-scale organization of the arrangement, mapping operators for controlling the local organization of elements, and merging operators for mixing different arrangements. These operators are designed so as to guarantee a stationary result meaning that the produced arrangements will always be repetitive. We show that this simple set of operators is sufficient to reach a much broader variety of arrangements than previous methods. Editing the script leads to predictable changes in the synthesized arrangement, which allows an easy iterative design of complex structures. Finally, our operator set is extensible and can be adapted to application-dependent needs.
article.pdf (24.77 Mo) Télécharger le fichier
supplemental-results.pdf (2.58 Mo) Télécharger le fichier
supplemental-user-study.pdf (4.7 Mo) Télécharger le fichier
tutorial-user-study.pdf (1.43 Mo) Télécharger le fichier
hal-01520258 , version 1 (10-05-2017)
Hugo Loi, Thomas Hurtut, Romain Vergne, Joëlle Thollot. Programmable 2D Arrangements for Element Texture Design. ACM Transactions on Graphics, 2017, 36 (3), pp.Article No. 27 ⟨10.1145/2983617⟩. ⟨hal-01520258⟩
2280 Consultations
1534 Téléchargements
