Embedding Interoperability in System of Systems: Definition and Characterization of Fundamental Requirements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The main objective of this communication is to discuss the engineering of a System of Systems (SoS), including interoperability concept. More precisely, the here presented research focuses on the fundamental requirements to consider in a System of Systems Engineering (SoSE) project and that have to be maintain during the entire life cycle of a SoS. First, the concept of interoperability, according to its definition and its characteristics, is presented. Then, the concept of SoS is presented in the same manner. This leads to introduce and present the possible links between System of Systems and interoperability. These links are (1) clarified and defined, (2) re-expressed to meet requirements’ definition and (3) not related to a given SoS in order to be generic.
978-3-642-32775-9_25_Chapter.pdf (87.57 Ko) Télécharger le fichier
hal-01520440 , version 1 (10-05-2017)
Paternité
Nicolas Daclin. Embedding Interoperability in System of Systems: Definition and Characterization of Fundamental Requirements. 13th Working Confeence on Virtual Enterpries (PROVE), Oct 2012, Bournemouth, United Kingdom. pp.245-253, ⟨10.1007/978-3-642-32775-9_25⟩. ⟨hal-01520440⟩
84 Consultations
69 Téléchargements
