Local texture-based color transfer and colorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Graphics Année : 2017
This paper targets two related color manipulation problems: Color transfer for modifying an image's colors and colorization for adding colors to a grayscale image. Automatic methods for these two applications propose to modify the input image using a reference that contains the desired colors. Previous approaches usually do not target both applications and suffer from two main limitations: possible misleading associations between input and reference regions and poor spatial coherence around image structures. In this paper, we propose a unified framework that uses the textural content of the images to guide the color transfer and colorization. Our method introduces an edge-aware texture descriptor based on region covariance, allowing for local color transformations. We show that our approach is able to produce results comparable or better than state-of-the-art methods in both applications.
paperExtended.pdf (68.73 Mo) Télécharger le fichier
hal-01520729 , version 1 (10-05-2017)
Benoit Arbelot, Romain Vergne, Thomas Hurtut, Joëlle Thollot. Local texture-based color transfer and colorization. Computers and Graphics, 2017, Virtual Special Section on Expressive 2016, 62, pp.15 - 27. ⟨10.1016/j.cag.2016.12.005⟩. ⟨hal-01520729⟩
795 Consultations
202 Téléchargements
