A New Approach to High Impedance Fault Detection Based on Correlation Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Najmeh Faridnia
  • Fonction : Auteur
  • PersonId : 1008007
Babak Doostani Dezfuli
  • Fonction : Auteur
  • PersonId : 1008009
Detection of High Impedance Fault (HIF) that is mainly occurred in MV power systems has been a challenge due to its low current magnitude. A new HIF detection approach based on correlation functions is applied on the voltage and current signals in this paper. Twelve indices based on correlation functions are implemented and tried on a lot of cases. Some of them which have clearly different values for no-fault and HIF conditions are chosen. Simulation results prove the efficiency of proposed method for HIF detection.
978-3-642-33409-2_47_Chapter.pdf (192.75 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01521398 , version 1 (11-05-2017)
Najmeh Faridnia, Haidar Samet, Babak Doostani Dezfuli. A New Approach to High Impedance Fault Detection Based on Correlation Functions. 8th International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2012, Halkidiki, Greece. pp.453-462, ⟨10.1007/978-3-642-33409-2_47⟩. ⟨hal-01521398⟩
66 Consultations
157 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
