Improved POS-Tagging for Arabic by Combining Diverse Taggers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Maytham Alabbas
  • Fonction : Auteur
  • PersonId : 1008016
Allan Ramsay
  • Fonction : Auteur
  • PersonId : 1008017
A number of POS-taggers for Arabic have been presented in the literature. These taggers are not in general 100% accurate, and any errors in tagging are likely to lead to errors in the next step of natural language processing. The current work shows an investigation of how the best taggers available today can be improved by combining them. Experimental results show that a very simple approach to combining taggers can lead to significant improvements over the best individual tagger.
978-3-642-33409-2_12_Chapter.pdf (83.56 Ko) Télécharger le fichier
hal-01521402 , version 1 (11-05-2017)
Paternité
Maytham Alabbas, Allan Ramsay. Improved POS-Tagging for Arabic by Combining Diverse Taggers. 8th International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2012, Halkidiki, Greece. pp.107-116, ⟨10.1007/978-3-642-33409-2_12⟩. ⟨hal-01521402⟩
57 Consultations
137 Téléchargements
