Multi-classify Hybrid Multilayered Perceptron (HMLP) Network for Pattern Recognition Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces a Hybrid Multilayered Perceptron (HMLP) based classifier known as the Multi-Classify HMLP network (MCHMLP). This network is shown to be able to enhance the performance accuracy when compared to the conventional HMLP network. The Multi-Classify HMLP network architecture is trained using a Modified Recursive Prediction Error (MRPE). This study uses three benchmark datasets in order to measure the capability of the network. The results show that the proposed Multi-Classify HMLP network provides a significant improvement over the conventional HMLP network for pattern recognition applications.
978-3-642-33409-2_3_Chapter.pdf (89.59 Ko) Télécharger le fichier
hal-01521433 , version 1 (11-05-2017)
Paternité
Fakroul Ridzuan Bin Hashim, John J. Soraghan, Lykourgos Petropoulakis. Multi-classify Hybrid Multilayered Perceptron (HMLP) Network for Pattern Recognition Applications. 8th International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2012, Halkidiki, Greece. pp.19-27, ⟨10.1007/978-3-642-33409-2_3⟩. ⟨hal-01521433⟩
74 Consultations
71 Téléchargements
