Output-only subspace and transfer matrix-based damage localization and quantification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with vibration-based damage localization and quantification from output-only measurements. We describe an approach which operates on a data-driven residual vector that is statistically evaluated using information from a finite element model, without updating the parameters of the model. First, the damaged elements are detected in statistical tests, and second, the damage is quantified only for the damaged elements. We propose a new residual vector in this context that is based on the transfer matrix difference between reference and damaged states, and compare it with a previously introduced subspace-based residual. We show localization and quantification on both residuals in simulations.
paper.pdf (402.86 Ko) Télécharger le fichier
hal-01522138 , version 1 (12-05-2017)
  • HAL Id : hal-01522138 , version 1
Md Delwar Hossain Bhuyan, Eva Viefhues, Michael Döhler, Yann Lecieux, Laurent Mevel, et al.. Output-only subspace and transfer matrix-based damage localization and quantification. IOMAC - 7th International Operational Modal Analysis Conference, May 2017, Ingolstadt, Germany. ⟨hal-01522138⟩
618 Consultations
102 Téléchargements
