Abstract : The isolation of a computing environment is an integral part of a digital forensic process. Isolation helps prevent evidence contamination and possible tampering. This paper focuses on the process of isolating instances in cloud computing systems. Several conditions are specified to serve as a guide for the successful isolation of cloud instances. Also, the complications that can arise during a cloud forensic investigation are discussed.
https://hal.inria.fr/hal-01523713 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, May 16, 2017 - 5:10:22 PM Last modification on : Sunday, November 22, 2020 - 12:52:02 PM Long-term archiving on: : Friday, August 18, 2017 - 12:50:55 AM
Waldo Delport, Martin Olivier. Isolating Instances in Cloud Forensics. 8th International Conference on Digital Forensics (DF), Jan 2012, Pretoria, South Africa. pp.187-200, ⟨10.1007/978-3-642-33962-2_13⟩. ⟨hal-01523713⟩
