Isolating Instances in Cloud Forensics - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2012
The isolation of a computing environment is an integral part of a digital forensic process. Isolation helps prevent evidence contamination and possible tampering. This paper focuses on the process of isolating instances in cloud computing systems. Several conditions are specified to serve as a guide for the successful isolation of cloud instances. Also, the complications that can arise during a cloud forensic investigation are discussed.
978-3-642-33962-2_13_Chapter.pdf (915.22 Ko) Télécharger le fichier
Dates and versions
hal-01523713 , version 1 (16-05-2017)
Attribution
Identifiers
Cite
Waldo Delport, Martin Olivier. Isolating Instances in Cloud Forensics. 8th International Conference on Digital Forensics (DF), Jan 2012, Pretoria, South Africa. pp.187-200, ⟨10.1007/978-3-642-33962-2_13⟩. ⟨hal-01523713⟩
96 View
203 Download
Share
