Context-Based File Block Classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Because files are typically stored as sequences of data blocks, the file carving process in digital forensics involves the identification and collocation of the original blocks of files. Current file carving techniques that use the signatures of file headers and footers could be improved by first classifying each data block in the storage media as belonging to a given file type. Unfortunately, file block classification techniques tend to have low accuracy. One reason is that they do not account for compound files that contain subcomponents encoded as different data types. This paper presents a context-based classification approach that accounts for compound files and improves on block-by-block classification schemes by exploiting the contiguity of file blocks belonging to the same file on the storage media.
978-3-642-33962-2_5_Chapter.pdf (1.37 Mo) Télécharger le fichier
hal-01523720 , version 1 (16-05-2017)
Paternité
Luigi Sportiello, Stefano Zanero. Context-Based File Block Classification. 8th International Conference on Digital Forensics (DF), Jan 2012, Pretoria, South Africa. pp.67-82, ⟨10.1007/978-3-642-33962-2_5⟩. ⟨hal-01523720⟩
88 Consultations
137 Téléchargements
