A Multi-agent Based Negotiation for Supply Chain Network Using Game Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper focuses on the single-issue negotiation between Manufacture Agent (MA) and Material Supplier Agent (MSA) of the supply chain. MSA resorts to find partners to cooperate when it cannot finish the order independently. A two stage negotiation protocol is proposed. The cooperative game is combined with MA-Stackelberg game to resolve the negotiation problem. It is used to establish the coalitions. Then, the final determined coalition negotiates with MA to reach an agreement using the Stackelberg game. Protocols without concession and with concession are respectively discussed. Simulations and comparisons are provided to verify the effectiveness and superiority of the proposed protocol.
978-3-642-33980-6_34_Chapter.pdf (184.64 Ko) Télécharger le fichier
hal-01524237 , version 1 (17-05-2017)
Paternité
Fang Yu, Toshiya Kaihara, Nobutada Fujii. A Multi-agent Based Negotiation for Supply Chain Network Using Game Theory. International Conference on Advances in Production Management Systems (APMS), Sep 2011, Stavanger, Norway. pp.299-308, ⟨10.1007/978-3-642-33980-6_34⟩. ⟨hal-01524237⟩
153 Consultations
100 Téléchargements
