Symbolic OBDD Assembly Sequence Planning Algorithm Based on Unordered Partition with 2 Parts of a Positive Integer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Zhoubo Xu
  • Fonction : Auteur
  • PersonId : 990791
Tianlong Gu
  • Fonction : Auteur
  • PersonId : 990789
Rongsheng Dong
  • Fonction : Auteur
  • PersonId : 1008460
To improve solution efficiency and automation of assembly sequence planning, a symbolic ordered binary decision diagram (OBDD) technique for assembly sequence planning problem based on unordered partition with 2 parts of a positive integer is proposed. To convert the decomposition of assembly liaison graph into solving unordered partition with 2 parts of positive integer N, a transformation method from subassembly of the assembly to positive integer N is proposed, the judgment methods for the connectivity of a graph and geometrical feasibility of each decomposition combined with symbolic OBDD technique is proposed too, and all geometrically feasible assembly sequences are represented as OBDD-based AND/OR graph. Some applicable experiments show that the symbolic OBDD based algorithm can generate feasible assembly sequences correctly and completely.
978-3-642-32891-6_29_Chapter.pdf (170.19 Ko) Télécharger le fichier
hal-01524943 , version 1 (19-05-2017)
Paternité
Zhoubo Xu, Tianlong Gu, Rongsheng Dong. Symbolic OBDD Assembly Sequence Planning Algorithm Based on Unordered Partition with 2 Parts of a Positive Integer. 7th International Conference on Intelligent Information Processing (IIP), Oct 2012, Guilin, China. pp.226-233, ⟨10.1007/978-3-642-32891-6_29⟩. ⟨hal-01524943⟩
39 Consultations
67 Téléchargements
