The Representation of Indiscernibility Relation Using ZBDDs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The indiscernibility relation is the basic concept in Rough set theory, a novel representation of indiscernibility relation using Zero-Suppressed BDDs is proposed in this paper. Through introducing the indiscernibility matrix and the indiscernibility graph, we put forward the encoding of the variable and give the characteristic function. Once the characteristic function is constructed, it can be represented using ZBDDs.And further, combined with an example, we analyze the effectiveness of this method. It provides a basis for deal with rough set computing.
978-3-642-32891-6_28_Chapter.pdf (263.69 Ko) Télécharger le fichier
hal-01524971 , version 1 (19-05-2017)
Paternité
Qianjin Wei, Tianlong Gu, Fengying Li, Guoyong Cai. The Representation of Indiscernibility Relation Using ZBDDs. 7th International Conference on Intelligent Information Processing (IIP), Oct 2012, Guilin, China. pp.216-225, ⟨10.1007/978-3-642-32891-6_28⟩. ⟨hal-01524971⟩
42 Consultations
220 Téléchargements
