FPGA-Based Image Acquisition System Designed for Wireless - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Introduced micro-wireless transmission system image acquisition the overall structure, each part of the overall design ideas and works theory. Designed SBBC camera interface and data cache control module, analysis of the TCP / IP communication protocol standard structure and characteristics, and on this basis, the design of a non-standard short-range wireless communication protocol. System which controlled by the input and output module is based on FPGA, the system collected data alternately to the outer SDRAM, this realized the image data collection; Ethernet interface controller also designed in FPGA to achieve the image data transmit through wireless. The results show that: under normal conditions, the wireless communication module can be complete, accurate, stable wireless data transceiver functions.
978-3-642-32891-6_47_Chapter.pdf (71.06 Ko) Télécharger le fichier
hal-01524984 , version 1 (19-05-2017)
Paternité
Haohao Yuan, Jianhe Zhou, Suqiao Li. FPGA-Based Image Acquisition System Designed for Wireless. 7th International Conference on Intelligent Information Processing (IIP), Oct 2012, Guilin, China. pp.382-386, ⟨10.1007/978-3-642-32891-6_47⟩. ⟨hal-01524984⟩
54 Consultations
316 Téléchargements
