On active sampling of controlled experiments for QoE modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
For internet applications, measuring, modeling and predicting the quality experienced by end users as a function of network conditions is challenging. A common approach for building application specific Quality of Experience (QoE) models is to rely on controlled experimentation. For accurate QoE modeling, this approach can result in a large number of experiments to carry out because of the multiplicity of the network features, their large span (e.g., band-width, delay) and the time needed to setup the experiments themselves. However, most often, the space of network features in which experimentations are carried out shows a high degree of uniformity in the training labels of QoE. This uniformity, difficult to predict beforehand , amplifies the training cost with little or no improvement in QoE modeling accuracy. So, in this paper, we aim to exploit this uniformity, and propose a methodology based on active learning, to sample the experimental space intelligently, so that the training cost of experimentation is reduced. We prove the feasibility of our methodology by validating it over a particular case of YouTube streaming, where QoE is modeled both in terms of interruptions and stalling duration.
InternetQoE2017.pdf (974.67 Ko) Télécharger le fichier
hal-01525723 , version 1 (22-05-2017)
Muhammad Jawad Khokhar, Nawfal Abbassi Saber, Thierry Spetebroot, Chadi Barakat. On active sampling of controlled experiments for QoE modeling. ACM SIGCOMM 2017 2nd Workshop on QoE-based Analysis and Management of Data Communication Networks (Internet-QoE 2017), Aug 2017, Los Angeles, United States. ⟨10.1145/3098603.3098609⟩. ⟨hal-01525723⟩
467 Consultations
345 Téléchargements
