Large brain effective network from EEG/MEG data and dMR information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Over the past 30 years, neuroimaging has become a predominant technique. One might envision that over the next years it will play a major role in disclosing the brain's functional interactions. In this work, we use information coming from diffusion magnetic resonance imaging (dMRI) to reconstruct effective brain network from two functional modalities: electroencephalography (EEG) and magnetoen-cephalography (MEG).
Belaoucha_prni17.pdf (3.23 Mo) Télécharger le fichier
hal-01533445 , version 1 (06-06-2017)
Paternité
  • HAL Id : hal-01533445 , version 1
Brahim Belaoucha, Théodore Papadopoulo. Large brain effective network from EEG/MEG data and dMR information. PRNI 2017 - 7th International Workshop on Pattern Recognition in NeuroImaging, Jun 2017, Toronto, Canada. ⟨hal-01533445⟩
343 Consultations
180 Téléchargements
